cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Is it possible to format custom ticket fields ?
I am new to the product and still getting to grips with it, I have created a custom ticket for the creation of a new user there are selection options using Ticket Custom Fields for the different printers available however we have a large number of printers is there are a way to group the printers into groups or even have them in columns as the custom fields appears to only only you to enter a string of values. Ideally I would like to group the printers together, the same would apply to the user application list
0 Kudos
1 Reply
Hi stewartmyles​,
Grouping values within a custom field is not possible, however this sort of functionality is available using the Assets feature.
Have you considered using assets in this way?
-Midnight
0 Kudos
