cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
How to I build approvals for only one Company?
I have struggled enough and need to ask for help.  We have one customer so far that wants to approval all tickets before we address them.
Only problem I have is when we setup either a client or location approver process, it doesn't limit to just their Company, but rather EVERY ticket created then requires approval.
Please tell me what little thing I'm overlooking.
Sincerely,
Mark D
0 Kudos
1 Reply
Level 9
Hi Mark,
If your company's privacy policy allows it, I would recommend that you post screenshots of your current configuration settings.
Related Configuration:
1Setup > Companies & Locations
2Setup > Tickets > Request Types
3Setup > Processes > Change Advisory Boards
4Setup > Processes > Approver Roles
5Setup > Processes > Location Approvers
6Setup > Processes > Department Approvers
7Setup > Processes > Approval Processes
That will ensure that you receive the most accurate answer from the Thwack community.
Regards,
Isaiah Carriere
SolarWinds Consultant
Adeptec - SolarWinds Authorized Partner
