cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 7
How do I enable Dashboard for some Web Help Desk tech users?
I'd like to turn on Dashboard for some tech users but not all
I looked through Setup and it seems the only way to enable Dashboard is through Tech Permisions
What if all my tech users are in a Default permissions group and I only want some of those users to have dashboard while others I do not?
0 Kudos
1 Reply
Highlighted
Level 14
Re: How do I enable Dashboard for some Web Help Desk tech users?
You could create a duplicate permissions group then just disable the dashboard for that group save it, move your users.
0 Kudos
