Bug: The request detail screen is truncating words across a set width of frame instead of properly formatting them to the next line. (See screenshot):
Workaround: If you edit the Column Set and remove "Display Full Text in Request and Notes" the system will display the text as a single line with a ",,," to indicate further content.bshopp
