cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
SEUM as a module, is it possible to point to a different DB than its NPM/APM host?
Jump to solution
If I'm running SEUM on a NPM or APM box is it possible to configure the SEUM module to point at its own databse rather than the NPM or APM db?
0 Kudos
1 Solution
Level 9
Hello Andrew,
I'm afraid it is not possible. SEUM does not access database directly, it shares the same infrastructure installed with APM/NPM which is responsible to access database.
H.
0 Kudos
1 Reply
Level 9
Hello Andrew,
H.
0 Kudos
