cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Exchange WMI Monitor - Multi-Instance?
I would LOVE to get this working to prove to the bosses that we do not need a tool like Quest Spotlight but I'm having some problems with some of the counters... I'm running Exchange 2007 (mailbox role) on Server 2008 and while most of the counters work i'm having problems with a few:
Log Generation Checkpoint Depth - Bad Input parameter (Instance "information store" does not exist in the specified category)
Information Store: I/O Database Reads Average Latentcy - Bad input parameter (Instance "information store/_total" does not exist in the specified category)
Information Store: I/O Database Writes Average Latency - Same error as above
All the "Store:RPC..." counters are showing a "Category does not exist error" or "XXX is marked as multi-instance"
and I cannot see the mail submission performance counters. If I can remove any of these when monitoring a mailbox server I'll go ahead and do that but I'm thinking that some of these (at least) should be working. I have gone through the WMI testing stuff and everything seems to be correct. I can locate these WMI counters from the Orion server when I use wbemtest. Any ideas on why it's not working?
0 Kudos
Level 18
I'm also seeing this. Using the Perfmon counters (not WMI), where other items are working fine. It's just a handful that are giving category or instance errors. When I check on the server, they appear to all be there.
Thanks!
Leon Adato | Head Geek
"Measure what is measurable,
and make measurable what is not so." - Gallileo
0 Kudos
Level 10
Actually I've noticed this too, what version of APM are you running?
We just upgraded to 3.5 and I noticed most of my disk related WMI counter APMs stopped working with the same error, but only if they were pointed at Win 2k8 and 2k8 R2 machines.  However if I toss these same counters into Perfmon they work great.
If I use the wizard to add WMI counters, I notice that there are only a handful of catagories that I can choose performance counters on....
And that's about it.  I can still monitor services and use scripts fine but particular performance counters (That worked fine when I was using 3.0) are unavailable.
UAC is off and the account polling the counters is a local admin on the box.
0 Kudos
Having a similar problem with Performance Counters against 2008 Exchange Servers.  Set up a number of polls monitoring various Exchange Transport Queues and Mail Store metrics.  All is well for awhile (days and weeks) then I get "Access to the Registry Key xxxx denied" and all of the polls for that particular server fail.  Verified that the user ID being used still had admin access  to that server.  When I go back and try to browse the Performance Counters for that server I now only see a handful of categories very similar to if not exaclty as shown in the post from kb1lxm.  Had these polls working against 20 Exchange servers and over the past few weeks have seen this failure against 5 of those servers and had to unmanage these monitors for those servers.   Running NPM 10.1.1 with APM 3.5.
0 Kudos
I did notice that WMI Monitor checks work for those same counters, but until there is a fix (APM 4.0.1 maybe?) I'll just have to use those.
0 Kudos
There was hotfix for performance counter issues released for APM 3.5. Did you apply it?
Are those errors you can see permanent failures or random failures?
So perfmon is working - but did you try it remotely or locally on the target node?
You are selecting 'WMI Monitor' as component type in the wizard? If so, please try also to browse for 'Performance Counter Monitor' and check if it has the same results. If it shows more counters available, then it could help to rebuild WMI as described in the WMI troubleshooting steps.
0 Kudos
I am also getting this error:
Bad input parameter. Instance 'Information Store/_Total' does not exist in the specified Category.
Can anyone let me know how to resolve.
Regards,
Damian
0 Kudos
Revisiting this issue, is there a solution?
I'm getting these errors particularly with Exchange 2010 templates.  Perviously I had the "registry key denied" error, which was kind of resolved with a restart of the Remote Registry service in Windows.
Now, even a restart does not help - I simply get the Bad input parameters error.
Using NPM 10.2 and APM 4.2.
0 Kudos
I'm having a similar problem with Active Directory monitors against two Server 2008 machines. I just tried restarting Remote Registry (which restarted WINS and DFS Namespace) and it worked on both servers. I wonder if this is a SolarWinds problem or a Server 2008 problem.
0 Kudos
Can you clarify, are the issues you are having with APM or the WMI Monitor free tool? I want to bring this to the correct group's attention.
Thanks.
Steve
0 Kudos
I'm running APM 4.2.0 SP1. I just opened a ticket: #302028. Thank you.
0 Kudos
What is the verdict? I am seeing the "Bad input parameter" error as well for some NTDS\ perfmon counters within the active directory components on some hosts.
-Shane
Loop1 Systems
www.loop1systems.com
0 Kudos
Level 13
Verify that your categories and values are spelled correctly and that spaces are as required for the counters you are interested in.
0 Kudos
