I'm running the helpdesk for tracking issues across multiple sites, I know I'm not facing this issue yet but.. I'm sure I will at some point- same name at two different sites.
ok I'm using the header for authentication as this is for school helpdesk with shortcut that puts the required fields in.
ideally what I'm after is a way to say I can have multiple usernames with the same login but require a site ID or company field.
example
both are different people:
joeblogs is a member of site A
joeblogs is a member of site B
header could then be something along the lines of ?username= ?siteID=
Is this possible at all?
Ben
