cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
Web Help Desk OS servers
Jump to solution
Hi Guys,
I'm planning to install WHD, my environment will be like this:
WHD server:
OS: Windows Srv 2016
App DB
OS: Suse Linux
Database instance: PostgreSQL
Is this scenario correct or both server should be Suse or Windows?
Thanks in advance for your support.
0 Kudos
1 Solution
Level 12
You should be fine with the setup you are suggesting.  There is not a listed OS requirement on the DB side (other than the DB engine needs to be able to run on that OS).  If you do go with Linux for both environments, WHD is not supported on Suse Linux and you would need to use a supported version of CentOS, Fedora, or RedHat.
-j_a_catlin
0 Kudos
Level 12
-j_a_catlin
0 Kudos
Thank you very much for the support. 🙂
0 Kudos
