cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
AXL credentials problems
Hello everyone,
I have been having several problems trying to add my AXL credential into the Solarwinds Callmanager configuration.
I have follow every step that the forum has told.
for example I do recieved the messaje "Cisco CallManager: AXL Web Service The AXL Web Service is working and accepting requests. Use HTTP POST to send a request.", with the user that I configured.
I will atach the screenshots of every test I did.
even I test to the communication to the AXL API Service with the command
url -k -u (Username) (Password) -H "Content-type: text/xml;" [https://( IP Address  of the CUCM):8443/axl/services/AXLAPIService?wsdl > axl_output.txt See sample below: ( I will atach the result)
Right know we are running VNQM version 2020.2.
0 Kudos
Level 8
I have already fixed the problem.
I had to uncheck the 3 boxes of authentication, and making sure that in the host file the ip and the hostname are correct
0 Kudos
where did you uncheck 3 boxes ?  somewhere in solarwinds or on the call managers themselves?  I am having the same issue as well.  If i navigate in my browser, I'm able to see a page with a bunch of xml information.  If i use post man from the poller, the call manager returns a generic 500 internal server error.
I'm stuck in limbo with all SIP trunks showing as not polled yet.
0 Kudos
