cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Sorting problems with widgets
When I make a trends widget,  it allows clicking on each header to sort the values.  These values are treated as pure text and don't sort in the correct order.
I'm wondering if this is a bug, configuration issue, or feature.
Example trend widget, attempted to sort by IOPs:
0 Kudos
1 Reply
Level 12
Hello, can you try upgrading to latest VMAN ver. 6.2.0? This issue should be solved in that release. Please let me know if it helped.
Milan
0 Kudos
