cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 9
Re: Skip certain volume label or drive letter in the Guest Storage Space Utilization script
Not that I am aware of
Tony
0 Kudos
Highlighted
Level 7
That's no good. I was under the impression before we purchased this that this was doable. I guess I will be contacting my sales engineer. Thanks for the quick reply.
0 Kudos
Highlighted
I think the certain guest drives can be filtered out from the alert. When you edit the Guest Storage Space Utilization alert, go to Criteria tab, 'Base Alert On' change to Attribute. There you may specify a xpath query  - something like this:
count( /virtualMachine/diskVolume[./mountPoint/text() !='D:\' and ./freeSpacePercentage<5])
Also change the Units to unit, aggreation function to Count, and change 'Triggers On' to 'Range', check Greather than > 0
This example should skip VMs, where only disk D:\ is nearly full.
Highlighted
Level 7
This work for me
