cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Need help with SWQL to limit Out of Box alert regarding snapshots
Jump to solution
Need help adjusting the Out of Box alert for VMs with Old Snapshots. We have a view environment that I do not want included for alerting.
I do not know SQL or SWQL, but it looks like I need to exclude the Cluster using vim_cluster.name value, just have no idea where or how to implement it
SELECT VirtualMachines.Uri, VirtualMachines.DisplayName FROM Orion.VIM.VirtualMachines AS VirtualMachines
where DayDiff(virtualmachines.OldestSnapshotDate,getdate())>14
0 Kudos
1 Solution
Level 13
INNER JOIN Orion.VIM.Hosts H ON VirtualMachines.Hostid=H.HostID
INNER JOIN Orion.VIM.Clusters C ON H.ClusterID=C.ClusterID
where
AND C.Name <>'NameofClusterNotToInclude'
Using a SWQL custom alert on VirtualMachines. Add the bold part to the edit'able part of the query and change to your clustername.
Hope it works!
0 Kudos
Level 13
where
Hope it works!
0 Kudos
Thank you so much. Worked on the first try
0 Kudos
