cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
VM Monitor for HyperV
Hi All
New to Solarwinds
Just installed Solarwinds VM Monitor for HyperV and after putting in my connection settings and click "test conncetion" I get "Successfully connected to server". However when I click dashboard I get this error:
WMI failure error occurred. Please check log for details.
So the questions are:
1) How do iI fix this?
2) Where are the logs location?
I'm running HyperV 2012 R2 Core (non GUI/non role version).
Thank you!
Tags (1)
0 Kudos
Level 9
I found the logs under C:\ProgramData\SolarWinds\VM Monitor for Hyper-V
When I got the same error "WMI Failure occured.  Please check log for details." my log showed the following repeated over and over:
2016-06-16 16:25:29,414 [1] ERROR SolarWinds.FreeTools.Logging.Logger - Invalid class
System.Management.ManagementException: Invalid class
   at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
   at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
   at HyperVLib.HyperVServer.GetMachines()
   at HyperVLib.HyperVMonitor.GetResult(Int32 failCount)
0 Kudos
Level 7
same Q here?  same credentials have been successfully used with ~3 other Hyper-V monitoring softwares (i'm testing to see which i want to keep)
0 Kudos
