cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
UDT showing multiple switches in the Current Network Connections when looking up a node
Good Morning - i am having issues with UDT when looking up nodes.  I can currently search for nodes but instead of seeing the direct connection of the switch to the node and see what port they are on, i see multiple switches all marked as indirect.  Has anyone else seen this?
Found the issue.
0 Kudos
