cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Using Orion SDK
I'm brand new to Solar Winds and to using the Orion SDK.  As a POC, I'm trying to run a query via the API.  My initial request (which uses code I copied from GitHub) is as follows:
https://myserver:17778/SolarWinds/InformationService/v3/Json/
My result contains a Status Code of 403 (forbidden).  Here's my code, in C#, and yes I'm passing in valid credentials and hostname:
        private static void Main()
                var swisClient = new SwisClient(Hostname, Username, Password);
                 const string query = @"SELECT TOP 1 AlertObjectID
                     FROM Orion.AlertActive
                     WHERE ISNULL(Acknowledged,0)!=1
                     ORDER BY TriggeredDateTime DESC";
                 JToken queryResult = swisClient.QueryAsync(query).Result;
                 var alertObjectId = (int)queryResult["results"][0]["AlertObjectID"];
        public Task<JToken> QueryAsync(string query, object parameters = null)
            return SwisCallAsync(client =>
                var request = new JObject();
                request["query"] = query;
                if (parameters != null)
                    request["parameters"] = JObject.FromObject(parameters);
                HttpContent content = new StringContent(request.ToString(), Encoding.UTF8, "application/json");
                return client.PostAsync("Query", content);
private async Task<JToken> SwisCallAsync(Func<HttpClient, Task<HttpResponseMessage>> doRequest)
            var handler = new WebRequestHandler
                Credentials = new NetworkCredential(_username, _password),
                PreAuthenticate = true,
                ServerCertificateValidationCallback = ValidateServerCertificate
            using (var client = new HttpClient(handler))
                client.BaseAddress = new Uri(string.Format("https://{0}:17778/SolarWinds/InformationService/v3/Json/", _hostname));
                HttpResponseMessage response = await doRequest(client);
     // response variable (above line) ends up containing a json string with a StatusCode of 403
                var result = JToken.Load(new JsonTextReader(new StreamReader(await response.Content.ReadAsStreamAsync())));
                if (!response.IsSuccessStatusCode)
                    throw new ApplicationException(string.Format("Server returned error: {0} {1}{2}{3}", (int)response.StatusCode,
                        response.ReasonPhrase, Environment.NewLine, result));
                return result;
Any help would be appreciated.
Thanks!
0 Kudos
