cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
error with case statement
I'm having issues with case statement, error says "no viable alternative at input 'From' in Select clause'..if anyone can assist it would be greatly appreciated..thanks
select top 100 from(
     select nodes.statusled,nodes.caption,
     '/orion/netperfmon/nodedetails.aspx?netobject=n:' + cast(nodes.nodeid as varchar(5)) as detailsurl,
     nodes.nodeid,starttime.message,starttime.eventtime as downtime,
     case when(
                    select top 1 eventtime from events as endtimetable
                    where endtimetable.eventtime > starttime.eventtime
                    and endtimetable.eventtype = 5001
                    and endtimetable.message like 'bgppeerstate is%'
                    and endtimetable.networknode = starttime.networknode
                    and eventtime is not null
                     order by endtimetable.eventtime
         ) is null then daydiff(tolocal(starttime.eventtime),getdate()) < 30
     else(
               where endtimetable.eventtime >starttime.eventtime
             )  end as upeventtime,datetrunc('minute',starttime.eventtime,
          case when (select top 1 eventtime from events as endtime
                           )end) as outagedurationinminutes
                       from events starttime
                      left join nodes on starttime.networknode=nodes.nodeid
                      where starttime.eventtype = 5000
                      and datetrunc('minute',starttime.eventtime)=adddate('minute',-1,getdate())
                      and starttime.message like 'bgppeerstate is down%'
                              and branch_voc = 'true'
) as uptimetable
order by caption asc, downeventtime desc
0 Kudos
1 Reply
It's not your case i think, it's that SWQL doesn't accept a query that doesn't pull from one of the built in tables, you can't do things like roll your own CTE's and whatnot.  It also doesn't really do wildcard type columns, you'd need to individually specify the name of the columns you want it to return instead of the select top 100 from ()
- Marc Netterfield, Github
