Hello,
I am monitoring Checkpoint Firewall nodes/modules using Orion without issue. But when I add monitoring to a modules' cluster, then the active module shows gaps in its monitoring, the standby module shows no gaps, and the cluster monitoring shows no gaps. What is causing gaps in monitoring (appears snmp related) on the active FW module only when the cluster is monitored too?
Thank You.
