cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Load Balancing and Elements per node
Jump to solution
I am trying to do some load balancing across my 6 additional pollers.
Since there seems to be no easy way I was going to write a query to find out the number of different elements on each node.
On the poller page there is this information for each poller:
Elements  10369
Network Node Elements281
Volume Elements857
Interface Elements9231
I know "ELEMENTS" is the total for the poller, but how do I find that information by node?
I know the Network Node Elements can be found in the interfaces table (which makes no sense)
Where do I find the Volume elements and Interface elements?
Labels (1)
Tags (2)
0 Kudos
1 Solution
murphym​ Are you just looking for a simple Node "A": 10 Interfaces; 13 Volumes list?
If so, this SWQL query should give you those results.
SELECT
n.Caption
,ISNULL(v.TotalVolumes,0) AS TotalVolumes
,ISNULL(i.TotalInterfaces,0) AS TotalInterfaces
FROM Orion.Nodes AS n
LEFT OUTER JOIN (SELECT Volumes.Node.NodeID,COUNT(*) AS TotalVolumes FROM Orion.Volumes GROUP BY Volumes.Node.NodeID) AS v ON v.NodeID=n.NodeID
LEFT OUTER JOIN (SELECT Interfaces.Node.NodeID,COUNT(*) AS TotalInterfaces FROM Orion.NPM.Interfaces GROUP BY Interfaces.Node.NodeID) AS i ON i.NodeID=n.NodeID
ORDER BY n.Caption
Nothing fancy there, just a simple list of nodes showing the count of interfaces and volumes per each node.
Let us know if you need further assistance.
Thank you,
-Will
SELECT
n.Caption
ORDER BY n.Caption
Thank you,
-Will
I actually had to change the select statement a bit because I think we have a little different layout and I wanted to see the engine it was on:
This is what I used....
SELECT n.engineid,
n.Caption
FROM dbo.Nodes AS n
LEFT OUTER JOIN (SELECT Volumes.NodeID,COUNT(*) AS TotalVolumes
    FROM dbo.Volumes
GROUP BY Volumes.NodeID) AS v ON v.NodeID=n.NodeID
LEFT OUTER JOIN (SELECT Interfaces.NodeID,COUNT(*) AS TotalInterfaces
    FROM dbo.Interfaces GROUP BY Interfaces.NodeID) AS i ON i.NodeID=n.NodeID
ORDER BY n.EngineID,n.Caption
It works great. much appreciated.
0 Kudos
