cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Universal Device Poller Chart, can't use InetAddress label as row to display
Hi all,
I'm trying to graph F5 Big-IP Node statistcs ( table OID : 1.3.6.1.4.1.3375.2.2.4.2.3 ).
The only usefull field to identify unique rows is ltmNodeAddrStatAddr (1.3.6.1.4.1.3375.2.2.4.2.3.1.2) which is of InetAddress kind.
Then I defined this field to be the label for my statistic indicator.
At this point, I should be able to graph my indicator, but here is what I get:
So here is my question:
Is there a way to convert an InetAddress OID from Hexadecimal to a human readable format on graphs ?
Thank you for your help,
Sylvain
0 Kudos
