cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
System.IO.FileNotFoundException: Could not load file or assembly 'Solarwinds.Logging, Version=2.0.0.
Hello,
I am trying to install new additional poller on windows 2019 server. getting below error while installing.(Orion Platform 2017.3.2 SP2)
System.IO.FileNotFoundException: Could not load file or assembly 'Solarwinds.Logging, Version=2.0.0.0, Culture=neutral, PublicKeyToken=aa802ff51e6c3813' or one of its dependencies. The system cannot find the file specified.
File name: 'Solarwinds.Logging, Version=2.0.0.0, Culture=neutral, PublicKeyToken=aa802ff51e6c3813'
at SolarWinds.Orion.ActiveDiagnostics.Engine.DiagnosticContract..ctor()
=== Pre-bind state information ===
LOG: DisplayName = Solarwinds.Logging, Version=2.0.0.0, Culture=neutral, PublicKeyToken=aa802ff51e6c3813
(Fully-specified)
LOG: Appbase = file:///C:/Users/Username/AppData/Local/Temp/tbbaljpm.n1g/SolarWinds/Orion/ActiveDiagnostics
LOG: Initial PrivatePath = NULL
Calling assembly : SolarWinds.Orion.ActiveDiagnostics.Engine, Version=1.11.0.259, Culture=neutral, PublicKeyToken=null.
LOG: This bind starts in default load context.
LOG: Using application configuration file: C:\Users\Username\AppData\Local\Temp\tbbaljpm.n1g\SolarWinds\Orion\ActiveDiagnostics\SolarWinds.Orion.ActiveDiagnostics.Engine.dll.config
LOG: Using host configuration file:
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.
LOG: Post-policy reference: Solarwinds.Logging, Version=2.0.0.0, Culture=neutral, PublicKeyToken=aa802ff51e6c3813
LOG: Attempting download of new URL file:///C:/Users/Username/AppData/Local/Temp/tbbaljpm.n1g/SolarWinds/Orion/ActiveDiagnostics/Solarwinds.Logging.DLL.
LOG: Attempting download of new URL file:///C:/Users/Username/AppData/Local/Temp/tbbaljpm.n1g/SolarWinds/Orion/ActiveDiagnostics/Solarwinds.Logging/Solarwinds.Logging.DLL.
LOG: Attempting download of new URL file:///C:/Users/Username/AppData/Local/Temp/tbbaljpm.n1g/SolarWinds/Orion/ActiveDiagnostics/Solarwinds.Logging.EXE.
LOG: Attempting download of new URL file:///C:/Users/Username/AppData/Local/Temp/tbbaljpm.n1g/SolarWinds/Orion/ActiveDiagnostics/Solarwi....
I stopped the antivirus on both main poller and new additional poller still facing the same issue.
0 Kudos
Level 9
Is the local firewall on the 2019 box off all the way and have you looked at the OU that server is in? Possibly not getting the same GP's like all your other servers? My first thought was HIPS/ePO but you said it was off.
0 Kudos
Level 12
Have you checked if Windows 2019 is supported with Orion 2017.3
0 Kudos
Yes, I have few solarwinds poller running on windows 2019 server
0 Kudos
