cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
Solarwinds Webconsole Login Page Customization
Jump to solution
Dear Experts,
I am trying to change the default background image in Solarwinds login page.
We just renamed our image with the default image file.
But I see a grey shade over my background image, as attached.
Could you help how to remove the grey filter here..
P.s. The image is entirely black
0 Kudos
1 Solution
Product Manager
Product Manager
/orion/images/Login/pattern-login-screen.png is used for the background image. This is a repeating pattern with transparent background The opacity is set to 50% which is defined in login.aspx in the section commented with /* rules designed to exist only in login page */
0 Kudos
Product Manager
Product Manager
0 Kudos
@tony.johnson
On a Fresh instance,  login.aspx doesn't have any entry, apart from below notes
This is a marker file generated by the precompilation tool, and should not be deleted!
Path: C:\Inet backup\inetpub\SolarWinds\Orion,
Could you please help to understand, in a New Solarwinds instances,,am i missing anything
0 Kudos
0 Kudos
Thanks Tony, This is exact thing, i been trying to achieve, Thanks again for the help
0 Kudos
Level 16
Me too! I want to add 'Don't forget to put the domain and a / in front of your username before complaining you can't log in' and a finger pointing straight at the screen.
0 Kudos
You can already add a banner message in Web Console settings.
- David Smith
0 Kudos
