cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
SEM V2020.4 Intall Wins 10
Jump to solution
Greetings community.
Does anyone know the requirements to install SEM 2020.4? Is it possible to install it in wins 10?
1 Solution
Product Manager
Product Manager
SEM is a Linux appliance that can run in your VMware, Hyper-V, AWS or Azure environments.  Check the link in the other response for details.
0 Kudos
this is the faul
0 Kudos
Thanks for your answer.
I downloaded the installer and unzipped it, when I mounted it in HyperV it notifies me that there are missing files. I have downloaded the document several times but I get the same error.
0 Kudos
Thanks for your answer, I guess the failure is something else.
0 Kudos
