cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
Restoring to Default Views
We have a production database that has been worked on.  In the process of it being "worked on" views of products have been modified.  Depending upon the device type (let's say a router) - we have 40 routers, some may have different views even if they are the same model, etc.  This has also happened for server hardware, switches, etc.  Is there a way to bring back all the default views in a single command?  Is there a way to save views (individually if possible) if we deem some to be beneficial?  We are running version 2019.4.1 (SAM, IPAM. NCM, NPM, VMAN, UDT)
Thanks.
Tags (4)
0 Kudos
1 Reply
Level 16
You should be to set these back to default in views by default type and for individual nodes you can set the view in node edit properties.
https://documentation.solarwinds.com/en/Success_Center/orionplatform/Content/Core-Views-by-Device-Ty...
0 Kudos
