cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Monitoring the node's CPU processes. Operation of the top 20 widget Monitored Processes by CPU Load
You need to visually see the processes that load the server.
Is there a widget?. Or maybe there is another solution?
The server is added to the Solarwinds monitoring system as a node.The server on Unix.
I looked there is a widget Top 20 Monitored Processes by CPU Load, but it gives only three processes, but the system processes more and the widget setting costs ten. How does it work? How can I see all processes and CPU load?
Thank you for any decision.
Waiting for a quick response.
Thanks.
Tags (1)
0 Kudos
1 Reply
Level 7
There is a separate server on Unix, How do I track CPU loading processes using Solarwinds Orion on this server? I added it to the node.
0 Kudos
