cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Big Data Volumes...
I am sure I am not the first to discuss this question but have had very little luck searching.  Our SolarWinds environment is in its infancy and we are running into something we would like to deal with differently.  On our summary page we have a resource being displayed called "Top 20 Volumes by Disk Space Used".  It is doing what it is designed to do, however we have "Big Data" (anywhere from 2TB to 3TB) volumes that we purposefully keep in the 95% to 98% ratio.  My question, Is there a way to keep these "Big Data" volumes off the resource I mention previously and off the summery page?
Look forward to hearing from someone,
Thad
Tags (1)
0 Kudos
1 Reply
Level 16
you can try using custom property for the volumes you dont need to show on the summary and then use it as filter in resource so that it doesnt appear...
0 Kudos
