cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
Authentication method used by Orion for communicating within its components APE, main poller, HA poo
Dear All,
SAM   encryption for internal communication across its components ( APE , Secondary servers, AWS) are TLS 1.2 enabled ,  I am trying to collect artifacts related to how authentication work in place.
During initial APE build setup, i will be using Orion username password to authenticate the APE installation. After that does orion platform by itself ensure any authentication methods,  for  RabbitMQ , Message Queuing , etc interaction .
Does it work through kind of certificate exchanges. kindly enlighten with some information please
0 Kudos
