cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Solar-PuTTY Session Credential Issue
When I start a telnet or a SSH session, Solar-PuTTY does not input the user name at the device login.  It inputs the password credential for the user name and nothing for the password credential.  I have tipple checked to make sure the proper user name and password is saved in the credentials section. PuTTY and DameWare SSH both works fine.  Any ideas to correct this issue in Solar-PuTTY?
Level 12
Michael, would you like to show this to us? If so, please send me an email with your availability: milan.hulik@solarwinds.com
0 Kudos
Im having the same issue. Any resolution?
0 Kudos
For telnet sessions you can try to increase the "Time to wait until entering password" in the Edit Session details.
0 Kudos
No resolution. I just use putty.
Michael Tautfest
Measurement Inc.
Network Operations
(919)683-2413 ext. 3025
0 Kudos
