cancel
Showing results for
Search instead for
Did you mean:
SolarMerakiCorrelation.txt
The built-in dependencies don't work as Meraki doesn't return this information as part of the SNMP data. A customer created a python script to create dependencies for their Meraki aps. This will set the parent node using custom properties this info is used to be used to silence alerts. SolarWinds does not provide support for this script it is being shared as is with no further direction.
Comments
Thanks!
Version history
Revision #:
1 of 1
Last update:
‎06-18-2019 01:27 PM
Updated by:
Contributors
