I have the following requirements for a monitor
If there are any files that exist in this location that end in "_N", with a "Date Modified" > 1 day (or 24 hours) beyond the current date, send a notification to the High Jump Developers group with the following instructions
I have a PS script that i used to work which can monitor the amount of files based on the folder name, age and type of files. I need help with modification of the script to include the name of the files
Below is the script i want to modify which gives me the list of files in the folder based on the criteria. In this PS i want to add the naming requirement.
[string]$path = "\\AArcWiVPWb10021\inetpub\ftproot\CustEDI\Replenishment"
[string]$filter = "*.xml"
[int]$maxAgeMinutes = 20
# Count of overdue files
$cnt = (Get-ChildItem -Path $path -Filter $filter | Where-Object {$_.CreationTime -lt [DateTime]::Now.AddMinutes(-$maxAgeMinutes)}).Count
if ($cnt -eq $null) {
$cnt = 0;
Write-Host 'Statistic: ' $cnt
write-host 'Message: ' "\\AArcWiVPWb10021\inetpub\ftproot\CustEDI\Replenishment"
Exit 0;
if ($cnt -gt 0)
exit (0)
} else {
exit (1)
Any help is greatly appreciated
