cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Take Control - Dual Monitors on Both Local and Remote?
We use Take Control to use our dual monitor workstations at work.  We also have dual monitor computers at home running the same size and resolution screens.  With Windows Remote Desktop Connection we can just check the box Display/Use all my monitors for the remote session and tah-dah, we have remote dual monitors at home same as at work.  With the powerful (?) Take Control we currently have to click the dual screen button at the top, select the monitor we want to use, then click inside that display to be actively in it.  Massively inefficient!!!!
Are we missing something or is Windows RDP more powerful and better suited for dual screen remote work that Take Control???
0 Kudos
