cancel
Showing results for
Search instead for
Did you mean:
Create Post
Storage Resource Monitor (SRM) - Latency Per Pool and Storage Array
  • The latency calculations take into account only the latest poll (last 15 minutes).
  • All LUNs with 0 IOPS or 0 ms latency are excluded. Pools will be missing from the report if all the LUNs are excluded.
  • Does not work for Netapp arrays
Labels (2)
Version history
Revision #:
1 of 1
Last update:
Thursday
Updated by:
