cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 13
Problem Installing Profiler on Linux Red Hat
Jump to solution
Receiving error message:
Checking Java installation:
./Profiler_Agent-linux-x86_64-4.12.2.bin: line 769: /opt/Profiler_Agent/jre/bin/java: cannot execute binary file
Problem executing Java, cannot continue without Java.
Please contact support for assistance.
Installed Profiler under root account
0 Kudos
1 Solution
Level 13
Problem resolved. I used the wrong code base. (64 bit and not the 32 bit)
0 Kudos
Level 13
0 Kudos
Level 17
Is this an Agent or Server install?
0 Kudos
