cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
Monitoring the QNAP NAS TS-EC1280U using Storage Resource Monitor v6.0 (2019.4) ?
Hi All,
I wonder if Storage Resource Monitor v6.0 (2019.4) can monitor the QNAP NAS TS-EC1280U https://www.qnap.com/en-au/product/ts-ec1280u?
If yes, what do I need to configure.
Thank you in advance.
0 Kudos
Wow, that's surprising my Synology NAS has an SMI-S provider than can be installed. I've never tried it out, though.
0 Kudos
@sturdyerdeI „think“ this is the same thing for QNAP. I believe this is not something that is native on the Storage but on a „broker machine“ I could be wrong but I still believe it is not supported to monitor QNAP with SRM
0 Kudos
As the QNAP doesn’t have SMI/S Support you can monitor it with NPM‘s/SAM‘s SNMP Functionality only.
Cheers
0 Kudos
