cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Monitor Inodes in SRM for Netapp stoarge
Hi Team,
Is it possible to Monitor Inodes in SRM for Netapp stoarge?
-/Sathya
0 Kudos
1 Reply
Product Manager
Product Manager
Currently SRM does not have a feature related to Inodes on NetApp. If you happen to own SAM there are some examples over in the SAM template forum that demonstrate using a PowerShell component to do some monitoring of those: https://thwack.solarwinds.com/t5/SAM-Documents/NetApp-inodes-7-mode/ta-p/537623
0 Kudos
