cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Problems with rules and filters not firing
I am just starting on my journey of implementing SEM and having some difficulties with setting up rules and alerting. I have configured our firewall to send logs to it and one of the events is :
  • Event Type
    NetworkAttack
  • EventInfo
    IPS Prevention Alert: WEB-ATTACKS Malformed HTTP Host Header 2
  • DetectionIP
    XXXX
  • ToolAlias
    XXXX
  • Severity
    6
  • InsertionTime
    2020-11-26 09:25:21
  • Manager
    swi-sem
  • SourcePort
    43336
  • DestinationPort
    80
  • InsertionIP
    swi-sem
  • DetectionTime
    2020-11-26 09:25:20
  • DestinationMachine
    XXXX
  • AlertActivityType
  • ManagerTime
    2020-11-26 09:25:21
  • Interface
    X0
  • SourceMachine
    XXXX
(I have removed ip addresses etc above).
I have created a filter which basically says:
Access.AlertActivityType = *WEB-ATTACKS Malformed HTTP Host Header 2*
and
Access.DetectionIP is equal to *<ip address of firewall>*
But nothing ever comes through the filter.
Its the same for my rule as well. I am using the same logic and want it to trigger an automated block rule through the active response but nothing ever gets flagged.
Can someone tell me what I am doing wrong?
thanks,
Paul
0 Kudos
1 Reply
Level 8
I think I must be missing something in my understanding on how these filters work...
I have read through the documentation and watched the solarwinds SEM video on creating filters but still to no avail. I was able to create a custom filter for the firewall and that worked but not sure why it worked compared to my other filters..
in that filter I used
AnyAlert.ToolAlias = *firewall name*
and I can see events coming through. I think it might be because I am not using the correct filters and although the event fields in the event are there, I am choosing them from the Access.<alert event> category...
I will keep trying...
0 Kudos
