cancel
Showing results for
Search instead for
Did you mean:
Create Post
Need some help with tls monitoring
Hi all.
I created a powershell script to check the registry to see if TLS 1.2 is enabled or not.
$regKey = 'HKLM:\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\tls 1.2\server'
$regProperty = 'enabled'
$target_value = 1
$reg_value = (Get-ItemProperty -Path $regKey -name $regProperty).$regProperty
Write-Host "Message: '$regKey\$regProperty' is currently set to '$reg_value'"
if ($reg_value -eq $target_value) {
Write-Host "Reg property value is equal to target value"
} else {
Write-Host "Reg property value is not equal to target value"
When I test it shows the correct answer but is listed as unknown.  The agent is installed on the machine in question.  Any input is greatly appreciated.
Revisions to this script are also appreciated.
Labels (2)
Comments
Your script doesn't have a statistic.   All sam script monitors require statistic outputs.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://thwack.solarwinds.com/t5/Geek-Speak-Blo...
Version history
Revision #:
1 of 1
Last update:
‎04-08-2020 12:09 PM
Updated by:
