Hello,
So based on another forum post I created (VARIABLE QUESTION - SAM AND NPM), can I get an answer for the following set of questions?
1) In the Alerts area, you have multiple types of Alerts to generate against:
A) Applications
B) Nodes
C) QOE Applications
D) Interfaces
E) F5
F) Group
Each set of alerts, take specific variables to alert against. Is there a way to obtain a list of the variables, for each specific type of alerts? I have the Application, Nodes and Interfaces working (and the F5 somewhat working). Problem is, I need to know how to pull against the DNS information for the QOE applications and the IP Address for this type of Alert? I typically get the ANSII code returned, for the IP Address.
And my other question revolves around using specific S.A.M. monitors and alerting against those? Does Solarwinds have a specific SQL monitor, that I can set an alert against? I know you can do service and process monitoring, but I am having some issues with the one validating correctly.
I am trying to work through these, one set at a time. However, I do need some assistance with the list of variables based on IP Address, DNS and Node Name. With each set of alerts, they each have their own defining variables. I need the entire list for those specific variables, if someone can point me in the correct direction or give me a link that actually contains them all?
Thank you
Dé
