cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
SQL Component Status for two Components on same Node
Hello,
I'm working on a SQL query and I'm not getting the results that I need.  I'm trying to get the custom table widget to supply the component status for two different component names for the same node.  I'm getting the below results, but it's showing duplicate entries.Capture.PNG
SQL Query:
SELECT n.statusled AS 'Status',
       n.caption   AS 'Device',
       CASE
         WHEN Substring(ca.multivaluestatistics,
              Charindex('A', ca.multivaluestatistics) + 4,
                     ( ( ( Len(ca.multivaluestatistics) ) - Charindex(':',
              Reverse(ca.multivaluestatistics)) ) -
                       Charindex(',', ca.multivaluestatistics)
              - 5 )) = 'N' THEN '0  minutes'
         ELSE Concat(Substring(ca.multivaluestatistics,
                            Charindex(':', ca.multivaluestatistics) + 1,
                                       Charindex(',',
                     - 3 )), '  minutes')
       END         AS Age,
       CASE
              Charindex('C', ca.multivaluestatistics) + 6,
                     ( ( ( Len(ca.multivaluestatistics) ) - Charindex('.',
              - 5 )) LIKE 'N%' THEN '0'
         ELSE Substring(ca.multivaluestatistics,
              - 5 ))
       END         AS Count,
       CASE
         WHEN Substring(ca.multivaluemessages,
              Charindex('A', ca.multivaluemessages) +
              4, ( (
                     ( Len(ca.multivaluemessages) )
                     Charindex(':', Reverse(ca.multivaluemessages))
              - Charindex('M', ca.multivaluemessages) )) LIKE 'N/A%' THEN
         '0 files were found in the directory'
         ELSE Substring(ca.multivaluemessages,
              4, ( (
              - Charindex('M', ca.multivaluemessages) ) + 100)
       END         AS Count_Info,
       n.bca_app_owner,
       CASE
         WHEN ad.componentname LIKE 'Custom Windows File Age%'
              AND ad.componentstatus = 'Down' THEN 'Down.gif'
              AND ad.componentstatus = 'Critical' THEN 'Critical.gif'
              AND ad.componentstatus = 'Unreachable' THEN 'Unreachable.gif'
              AND ad.componentstatus = 'Warning' THEN 'Warning.gif'
              AND ad.componentstatus = 'Unknown' THEN 'Warning.gif'
         ELSE 'Up.gif'
       END         AS 'File Status',
       ad.componentname,
       ad.componentstatus,
       CASE
         WHEN ad.componentname LIKE '%Epic BCA%'
         ELSE 'Up.gif'
       END         AS 'Service Status',
       CASE
         WHEN n.bca_pcs = 'Field Services - DV' THEN 'Deer Valley'
         WHEN n.bca_pcs = 'Field Services -JCL' THEN 'John C. Lincoln'
         WHEN n.bca_pcs = 'Field Services - MG' THEN 'Medical Group Office'
         WHEN n.bca_pcs = 'Field Services - NSSC' THEN 'NSSC'
         WHEN n.bca_pcs = 'Field Services - OSB' THEN 'Osborn'
         WHEN n.bca_pcs = 'Field Services - SHEA' THEN 'Shea'
         WHEN n.bca_pcs = 'Field Services - TPK' THEN 'Thompson Peak'
       END         AS 'Facility'
FROM   dbo.apm_component c
       JOIN dbo.apm_componentalertvariable ca
         ON ca.componentid = c.id
       JOIN dbo.apm_application a
         ON a.id = c.applicationid
       JOIN dbo.nodes n
         ON n.nodeid = a.nodeid
       JOIN dbo.apm_alertsdata ad
         ON ad.nodeid = n.nodeid
WHERE  n.caption NOT LIKE 'ARCHIVE-%'
       AND n.bca_app_owner = 'EMR Ambulatory'
       AND n.statusled != 'Unmanaged.gif'
ORDER  BY ( CASE
              WHEN n.status = 'Down' THEN 1
              WHEN ad.componentstatus = 'Down' THEN 2
              WHEN ad.componentstatus = 'Critical' THEN 3
              WHEN ad.componentstatus = 'Warning' THEN 4
              WHEN ad.componentstatus = 'Unreachable' THEN 5
              WHEN ad.componentstatus = 'Unknown' THEN 6
              WHEN ad.componentstatus = 'Up' THEN 7
            END ) ASC;
0 Kudos
1 Reply
Level 11
Not sure if my original post is clear enough.  When I run the query, I get two separate lines as the picture shows below.  I only want one row that contains the node status, and two component status. Does anyone have a recommendation?
0 Kudos
