I am having problems with getting WMI Monitors to work with SQL Servers. The servers are a mix of SQL 2008 and SQL 2005 and the OS's are varied as well.
Looking at the counters using the APMs Find Processes .... option it appears that the counter names have the SQL Instance name prepended to the counter name and therefore change with each server.
Has anyone else come across this, and have you found a way around it. Even the Solarwinds provided template fails, which is a little disappointing
