cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Need Help With Alert / HTTP Post / API Calls
Hi
I can get solarwinds to raise a request in our ticketing system (Manage Engine) via a http post, when the post is made I get the below reply, where I can see a request has been created with the ID of 2
<operating>
<status>Success</status>
<requestid>2</requestid>
</operating>
I want to close the request that was raised when the alert is no longer active, So in the reset actions I need to put another http post this time with the request ID in it.  This is where I am having the issue because I can not specify what the correct request id is.
Does anyone know how I can get this working?
0 Kudos
1 Reply
Level 17
can you share your post config?
I am having trouble with mine and keep getting 400 response from MESD.
I know the 2020.2 provides more options in POST alert action...still can't get successfully opened.
0 Kudos
