Cross posting this case here because SW support has been unable to provide a timely or helpful response to my team over the past few weeks. It could be that our environment is unique. Have any of you run into similar roadblocks with deploying the SW agent to docker containers? (Below is quoted/paraphrased from our support case.) Any tips or suggestions are welcome! cc:ljmckarns
I've been following this guide (http://www.solarwinds.com/documentation/en/flarehelp/orionplatform/content/core-container-add-container-service.htm) to add our swarm instance to Orion SAM, and have been unsuccessful. After customizing the cman-swarm.yml generated to match our environment (networks and access to the docker socket), I was only able to get the stack to start after removing the following lines:
depends_on:
- scope2orion
But, without these lines in, it does not seem to be communicating back to Orion. I've not seen any reference to what this dependency is in the documentation, or how to fulfill it.
System details:
OS: Ubuntu 16.04
# docker version
Client:
Version: 17.12.1-ce
API version: 1.35
Go version: go1.9.4
Git commit: 7390fc6
Built: Tue Feb 27 22:17:40 2018
OS/Arch: linux/amd64
Server:
Engine:
Version: 17.12.1-ce
API version: 1.35 (minimum version 1.12)
Go version: go1.9.4
Git commit: 7390fc6
Built: Tue Feb 27 22:16:13 2018
Experimental: false
Please let me know if I can provide additional information to assist in troubleshooting this issue.
I’m using the stack file as generated by Orion when adding a container service (Settings > All Settings > Manage container services > Add), only changing a few settings to match our internal customizations. [...] Also, I apologize if my question was unclear, its not “depends on” that I’m unclear on, but rather how its being used here. There’s a dependency listed (scope2orion) that isn’t being started by the stack file, nor is it mentioned anywhere in the “Add a container service” documentation I’ve found. The only reference I’ve see to this name at all has been here: https://hub.docker.com/r/derhally/scope2orion, but no indication that this is an officially supported Solarwinds container, nor that it needs to be running prior to the monitor or aggregator containers. [...]
