Hey everybody, i'm a newbie to Solarwinds and have a question about Linux/Unix Script Monitor. What I want to do is be able to remotely execute a shell script from the Linux/Unix Script Monitor. From reading documentation and looking at examples from Solarwinds I only see Perl scripts that are able to execute remotely. Can someone tell if it's possible to execute shell scripts the same way? If so, what is the command line I should use? The default shows "perl ${SCRIPT} arg1 arg2". I'm assuming that you could do something like "sh ${SCRIPT} arg1 arg2" or ./${SCRIPT} arg1 arg2"
(Note, I do not want to have to load the script on the machines prior. I want to be able to paste my script into the script body in Linux/Unix Script Monitor and execute remotely from there)
Thanks for any help
