cancel
Showing results for
Search instead for
Did you mean:
Create Post
Issue with Azure AKS monitoring
Hi all,
I am having issues deploying the kubernetes monitoring service. The agent has deployed and reporting to our Solarwinds server however the monitor service is failing with the error logs below:
time="2020-08-29T12:35:32Z" level=info msg="publishing to: orionaggregator-service.orion.svc.cluster.local:30043"
<probe> INFO: 2020/08/29 12:35:32.759414 command line args: --mode=probe --no-app=true --probe.docker=true --probe.docker.bridge=docker0 --probe.kubernetes=true --probe.publish.interval=5m0s --probe.spy.interval=30s --weave=false orionaggregator-service.orion.svc.cluster.local:30043
<probe> INFO: 2020/08/29 12:35:32.759489 probe starting, version 1.8.0, ID 7a7d0937d3e30496
<probe> INFO: 2020/08/29 12:35:32.768841 Control connection to orionaggregator-service.orion.svc.cluster.local starting
<probe> ERRO: 2020/08/29 12:35:32.769329 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 1s: websocket: bad handshake
<probe> INFO: 2020/08/29 12:35:33.398959 kubernetes: targeting api server https://172.16.64.1:443
<probe> ERRO: 2020/08/29 12:35:33.413651 conntrack stderr:NOTICE: Netlink socket buffer size has been set to 8388608 bytes.
<probe> INFO: 2020/08/29 12:35:33.435323 daemonsets are not supported by this Kubernetes version
<probe> INFO: 2020/08/29 12:35:33.438651 statefulsets are not supported by this Kubernetes version
<probe> INFO: 2020/08/29 12:35:33.438788 deployments are not supported by this Kubernetes version
<probe> INFO: 2020/08/29 12:35:33.492581 Publish loop for orionaggregator-service.orion.svc.cluster.local starting
<probe> ERRO: 2020/08/29 12:35:33.770633 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 2s: websocket: bad handshake
<probe> INFO: 2020/08/29 12:35:34.084972 Scope version 1.13.1 is available; please update at https://github.com/weaveworks/scope/releases/download/v1.13.1/scope
<probe> INFO: 2020/08/29 12:35:34.769489 Scope version 1.13.1 is available; please update at https://github.com/weaveworks/scope/releases/download/v1.13.1/scope
<probe> ERRO: 2020/08/29 12:35:35.771429 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 4s: websocket: bad handshake
<probe> ERRO: 2020/08/29 12:35:39.772124 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 8s: websocket: bad handshake
<probe> ERRO: 2020/08/29 12:35:47.772788 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 16s: websocket: bad handshake
<probe> WARN: 2020/08/29 12:36:03.422628 No node name and cannot obtain local pods, reporting all (which may impact performance): Get http://127.0.0.1:10255/pods/: dial tcp 127.0.0.1:10255: getsockopt: connection refused
<probe> ERRO: 2020/08/29 12:36:03.773636 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 32s: websocket: bad handshake
<probe> WARN: 2020/08/29 12:36:33.429383 No node name and cannot obtain local pods, reporting all (which may impact performance): Get http://127.0.0.1:10255/pods/: dial tcp 127.0.0.1:10255: getsockopt: connection refused
<probe> ERRO: 2020/08/29 12:36:35.774468 Error doing controls for orionaggregator-service.orion.svc.cluster.local, backing off 1m0s: websocket: bad handshake
Is anyone else having issues as well?
0 Kudos
1 Reply
Level 8
Hi
I'm also facing same kind of error. Any solution to resolve this?
Regards
Saby
0 Kudos
