cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
How do I monitor an Azure SQL Managed Instance?
Checked in Success Center but I couldn't find all I need.
I see the templates - do I copy then for each instance and set up accordingly?
Do I create a node with ICMP/remote polling and then attach the template there?
Do I copy the template and attach to a server with the Azure tools/pre-requisites installed and configure there?
It isn't clear.
0 Kudos
1 Reply
Level 9
I'm trying to find out the very same
0 Kudos
