cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
HTTP(s) Component monitor results
Hello,
I have trouble running HTTP(s) component monitor, I can't find the logic
My results :
"initial_value must be str or None, not bytes" (status down) when testing http://www.google.fr on port 80
whereas testing on the server :
[user@server ~]$ curl http://www.google.fr:80 --head
HTTP/1.1 200 OK
"initial_value must be str or None, not bytes" (status down) when testing https://www.google.fr on port 443
[user@server ~]$ curl https://www.google.fr:443 --head
HTTP/1.1 200 OK
Exactly the same with http://www.youtube.com & https://www.youtube.com
"status OK" when testing http://www.lequipe.fr on port 80
[user@server ~]$ curl http://www.lequipe.fr:80 --head
HTTP/1.1 301 Redirection https.
"initial_value must be str or None, not bytes" (status down) when testing https://www.lequipe.fr on port 443
[user@server ~]$ curl https://www.lequipe.fr:443 --head
HTTP/1.1 200 OK
"status OK" when testing http://www.free.fr on port 80
[user@server ~]$ curl http://www.free.fr:80 --head
HTTP/1.1 301 Moved Permanently
"initial_value must be str or None, not bytes" (status down) when testing https://www.free.fr on port 443
[user@server ~]$ curl https://www.free.fr:443 --head
HTTP/1.1 302 Moved Temporarily
"status OK" (????????) when testing http://www.lequipe.fr on port 443 (irrelevant, just for the test)
[user@server ~]$ curl http://www.lequipe.fr:443 --head
curl: (52) Empty reply from server
What is the magical behind this component ?
Labels (3)
0 Kudos
Level 7
We had a similar issue. Found that the HTTP monitor has issue if you are using agent as the preferred polling method on the monitor. After changing to Agentless for that particular application monitor it would work.
0 Kudos
I opened a ticket to support, it was a bug in the agent ; it has been corrected in 2020.2
0 Kudos
