cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 12
Easy Application Monitor Advanced Alerts
 One advanced alert can inform you of any problem in the applications you are monitoring with the Application Monitor add-in
Here's what your trigger should look like:
 The Reset Condition is the same, except you change is not equal to to equal to
Pretty simple!
Here's the Alert Message Text that we use:
The Reset Action  is a copy of the same message
0 Kudos
Level 9
how would you exclude a server or group of servers for this alert?
0 Kudos
Level 7
When I try and do that I get the following emailed to me - names changed to protect the innocent.
The Process GravitixService.exe on PatchLink Update on MYSERVER reported status Application is running at 6/4/2007 2:04:24 PM
 Gravitixserver.exe is the process, patchlink update is what I named it.. Why do I get both? I would prefer it to say:
The Process GravitixService.exe on MYSERVER reported status Application is running at 6/4/2007 2:04:24 PM
How can I do this?
0 Kudos
 Easy....
change Applications.FullName
to
Applications.ApplicationName
0 Kudos
I tried that and it still isnt working quite right.. Here is what I have written as an alert.
 Subject: ${Application.FullName} Status: ${Application.StatusDescription} at ${LastStatusChange}
Equates to: PatchLink Update on MYSERVER Status: Application is not running at 6/5/2007 8:31:48 AM
 So thats perfect! Here is where the problem comes in:
Message: The Process ${Applications.ApplicationName} on ${NodeName} reported status ${StatusDescription} at ${LastStatusChange}
Equates to:
The Process PatchLink Update on PatchLink Update on MYSERVER reported status Application is not running at 6/5/2007 8:31:48 AM
Notice how it repeates the process, or application name.. Seems like ${Applications.ApplicationName} is pulling it up twice somehow.. Any ideas?
0 Kudos
 Fire up the database manager and look at the applications  table - you can see the column names and the data that is in them. Just use the column name of the data you want
0 Kudos
Yeah, and you can export the table definitions for future reference...  I built a semi accurate DB map(schema), but when my laptop took a dirt nap I lost the original Visio file  😞
0 Kudos
I am trying to learn more about app monitoring and alerting.  My screen did not match the picture above and I don't seem to have the same level of granularity.  We are running Net Perf Mon ver 7 SLX.  Do I lack functionality to alert on application variables with this release?  If so, will upgrading allow me to easily create alerts on services?
0 Kudos
 Do you have the application monitor module?
0 Kudos
Yes, we have that module and I have been trying to determine if this is going to alert us when services are up or down.  Will it alert?  There isn't a great deal of "How-To's" in the pdf downloads so I am just trying to figure it all out.
0 Kudos
