cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Level 8
Does APE need to install ODBC driver for SAM to monitor Postgresql?
Hi, from the documentation I understand I need to install the ODBC driver on the Orion server. In my environment I have a APE server between the manager and the postgresql server, do I need to install the ODBC driver on the APE server as well?
https://documentation.solarwinds.com/en/success_center/SAM/Content/SAM-PostgreSQL-sw5792.htm
Jinqiang
0 Kudos
1 Reply
Highlighted
Level 15
Re: Does APE need to install ODBC driver for SAM to monitor Postgresql?
If the node that is running the PostgresSQL is being polled by that APE then yes you will.
0 Kudos
