Setting up a Powershell script that will load the PowerCLI module. It works fine from the Orion server, but when tested in the Powershell Monitor it refuses to load:
Import-Module : The specified module 'VMware.VimAutomation.Core' was not loaded because no valid module file was found in any module directory.
I've tried switching the polling to x64 and x86 with no luck. I've got PowerCLI 6.5 and Powershell 5.1 installed on the Orion server. I've also verified the PsModulePath has the directory. Not sure what I'm doing wrong here. I've opened a support case as well.
Any help would be appreciated!
