cancel
Showing results for
Search instead for
Did you mean:
Create Post
SAM Licenses by Group and Node
SAM License Usage by App and Group:
SELECT
c.Name AS [GROUP NAME]
,a.Name AS [APPLICATION NAME]
,CASE
    WHEN a.CustomApplicationType = 'ABXA' THEN '50'
    WHEN a.CustomApplicationType = 'ABSA' THEN '50'
    WHEN a.CustomApplicationType = 'ABIA' THEN '30'
    WHEN a.CustomApplicationType = 'ABTA' THEN '5'
    ELSE COUNT(a.Components.ComponentID)
END AS [LICENSES]
,CASE
    WHEN a.Unmanaged = 1 THEN 'YES'
    ELSE 'NO'
END AS [UNMANAGED?]
FROM Orion.APM.Application a
JOIN Orion.Container c ON c.MemberSnapshots.EntityID = a.NodeID
WHERE a.Components.Status <> 27 --Not Disabled
AND c.MemberSnapshots.EntityType = 'Orion.Nodes'
GROUP BY c.Name, a.Name, a.CustomApplicationType, a.Unmanaged
ORDER BY c.Name, a.Name, [LICENSES] DESC
SAM License Usage by Node:
SELECT
,a.Node.Caption AS [DEVICE NAME]
,CASE
END AS [LICENSES]
,CASE
    ELSE 'NO'
END AS [UNMANAGED?]
GROUP BY a.Node.Caption, a.Name, a.CustomApplicationType, a.Unmanaged
ORDER BY a.Name, [LICENSES] DESC
Tags (1)
Comments
Database scheme has changed. This query does not properly exclude components that are assigned but disabled.
thanks for the notice, updated to use SWQL and avoid any future schema changes
Thank you the SAM by node is exactly what I needed.
I get this error when I run both querys
Msg 208, Level 16, State 1, Line 1
Invalid object name 'Orion.APM.Application'.
Version history
Revision #:
1 of 1
Last update:
‎09-15-2014 07:15 PM
Updated by:
