cancel
Showing results for
Search instead for
Did you mean:
Create Post
Node Summary Report with Interfaces, Volumes, Applications
I see this request a lot where people want a list of all their nodes, plus all their related objects such as interfaces/volumes/app monitors.  Using normal SQL/SWQL it is a mess because every time you join another table you end up with lots of duplicated data like this:
That one database server had 126 rows using normal joins between all the interfaces and volumes and app monitors.
A while back tdanner posted an example of a query that used unions to make a cleaner set.  I saw how i could use that same method to build this SWQL report that I think does a much better job of presenting the relevant info about all the child objects being monitored on each node.
SELECT
    n.caption as Node,
    '/netperfmon/images/vendors/' + n.VendorIcon as [_IconFor_Node],
    n.DetailsUrl as [_LinkFor_Node],
    n.ipaddress as IP_Address,
    n.ObjectSubType as Polling_Method,
    n.StatusDescription as Status,
    '/Orion/images/StatusIcons/Small-' + n.StatusLED AS [_IconFor_Status],
    '' as [ ],
    n.nodeid as [_linkfor_ ],
    '0' as [_linkfor_order]
FROM orion.nodes n
--Where n.caption like '%${SEARCH_STRING}%'
UNION ALL (
SELECT
    (' - '+ I.Caption) as Interface,
    '/netperfmon/images/interfaces/' + i.InterfaceIcon AS [_IconFor_Interface],
    i.DetailsUrl as [_LinkFor_Interface],
    i.IPAddress.IPAddress,
NULL as Polling_Method,
concat(tostring(InPercentUtil),'% RX Utilization, ',tostring(OutPercentUtil),'% TX Utilization') as Status,
    '/Orion/images/StatusIcons/Small-' + i.Statusicon AS [_IconFor_Status],
    '' as [ ],
    i.nodeid as [_linkfor_ ],
    '1' as [_linkfor_order]
FROM Orion.NPM.Interfaces I
--Where i.node.caption like '%${SEARCH_STRING}%'
UNION ALL (
SELECT
    (' - '+V.Caption) as Volume,
    '/NetPerfMon/images/Volumes/' + V.VolumeTypeIcon AS [_IconFor_Volume],
    v.DetailsUrl as [_LinkFor_Volume],
    NULL as IP_Address,
    concat(round(v.VolumePercentUsed,0),'% of ',round(v.volumespaceavailable/1073741824,0),' GB total') as Status,
    '/Orion/images/StatusIcons/Small-' + v.StatusLED AS [_IconFor_Status],
    '' as [ ],
    v.nodeid as [_linkfor_ ],
    '2' as [_linkfor_order]
FROM Orion.Volumes V
--Where v.node.caption like '%${SEARCH_STRING}%'
UNION ALL (
SELECT
    (' - '+A.Name) as Application,
    '/orion/apm/images/statusicons/Small-App-Blank.gif' AS [_IconFor_Application],
    a.DetailsUrl as [_LinkFor_Volume],
    NULL as IP_Address,
    a.StatusDescription as Status,
    '/Orion/images/StatusIcons/Small-' + a.StatusDescription + '.gif' AS [_IconFor_Status],
    '' as [ ],
    a.nodeid as [_linkfor_ ],
    '3' as [_linkfor_order]
FROM Orion.APM.Application a
--Where A.node.caption like '%${SEARCH_STRING}%'
ORDER BY [_linkfor_ ], [_linkfor_order], node
-Marc Netterfield
Comments
Hi Mark,
Is there a specific table I run this query from on the NPM database?  I am VERY VERY new to opening the Orion hood.  This report is gold.
Don't run it in the database, this is written to be used inside a resource in the web console called "Custom Query"
Hello
Thanks for this - This looks brilliant - I wanted to know if it can be modified to run on the latest version of NPM. Because its giving a few errors when I put it in the SQL\WSQL query window.
We've just upgraded to NPM 12.4
Should need any changes to run in 12.4, I have it running on my lab right now.
It is written to be used inside the Custom Query resource though, not as a Custom Table
Once again, another terrific resource for the community to use.
Thank you for sharing, mesverrum​!
-Will
mesverrum​ thankyou for your query it is a massive help. Any chance someone would be kind enough to point out where I change this query to only display nodes with a specific custom peoperty (e.g. System). Baiscally adding a filter so we can target certain areas of the business?
Anyway to update this to the latest release?  When I try to run a custom query using this it just reports back "There was an error processing the request.".
Version history
Revision #:
1 of 1
Last update:
‎05-29-2018 07:27 PM
Updated by:
